Server Mods
- 0verzeal0us
- 6
Server Mods
If you want to download the server mods manually, you can (or by using built in mod manager). The current mods are:
They go into SteamLibrary\steamapps\common\sandstorm\Insurgency\Mods\modio
Please let me know if I've missed any!
I am neurodivergent which means that communication can be challenging for me. If you would like to know more about neurodiversity, please click here.
- Hairy Frog
- Full Member
- 6
Re: Server Mods
Each time I try ro conect to our server, I get an answer saying that I'm not conected to MOD IO, and I can't manage to fix this. However, each time I go to MOD IO through the game interface, I open the MOD IO window and see that I'm logged in ...... WTF ?
If a guy who lost his touch with the real world is a fool, what to think about people who are confusing
- Hanger and hatred
- Respect and fright
- Offense and fear
- Truth and belief
- Knowledge and information
- Love and concupiscence
- Being and having
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
Re: Server Mods
Description
This issue occurs whenever your Mod.io token becomes invalid. You can resolve this issue by renewing your token.
1) Navigate to: %localappdata%\Insurgency\Saved\Config\WindowsClient
2) Open the "Engine.ini" file.
3) Delete the bottom portion under [/Script/ModKit.ModIOClient] and save the file.
The next time you click on the Mods option in the in-game menu, you will have to re-accept the Mod.io terms of service. After that, a new token will be generated for you, which should fix the issue.
Re: Server Mods
If you're lazy like me, connecting through IP address bypasses the whole issue for some reason.
Ours is pinned in the sandstorm discord channel (87.98.157.13:7777).
- Hairy Frog
- Full Member
- 6
Re: Server Mods
Thx for the tips.
Rat, even a search in the whole PC didn't give a result. any hint about where I should find this directory ?
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
Re: Server Mods
You can open local app data in the run window (Windows + R key to open) and typing in %localappdata%,
or search for %localappdata% in the menu search bar,
or open Rat's folder directly though the path:
C:\Users\USERNAME\AppData\Local\Insurgency\Saved\Config\WindowsClient
(Just swich the "USERNAME" with your own username.)
The folder itself is hidden I believe, so you won't find it unless you use a direct path to open it or change the settings.
- Hairy Frog
- Full Member
- 6
Re: Server Mods
OK, file fixed, let's check ...
.... it worked !
.... it worked !
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
