Server Mods
0verzeal0us
7
Server Mods
Post by 0verzeal0us »
If you want to download the server mods manually, you can (or by using built in mod manager). The current mods are:
They go into SteamLibrary\steamapps\common\sandstorm\Insurgency\Mods\modio
Please let me know if I've missed any!
Fall forward. Sometimes, it’s the best way to figure out where you’re going. Never be discouraged, never hold back, give everything you got, and when you fall throughout life remember this: fall forward. Denzil Washington
We’re not the avatars we create. We’re not the pictures on the film stock. We are the light that shines through. All else is just smoke and mirrors. Distracting, but not truly compelling. Jim Carrey
I am neurodivergent which means that communication can be challenging for me. If you would like to know more about neurodiversity, please click here.
Hairy Frog
7
Re: Server Mods
Post by Hairy Frog »
Each time I try ro conect to our server, I get an answer saying that I'm not conected to MOD IO, and I can't manage to fix this. However, each time I go to MOD IO through the game interface, I open the MOD IO window and see that I'm logged in ...... WTF ?
If a guy who lost his touch with the real world is a fool, what to think about people who are confusing
- Hanger and hatred
- Respect and fright
- Offense and fear
- Truth and belief
- Knowledge and information
- Love and concupiscence
- Being and having
rat-rsv
7
Re: Server Mods
Post by rat-rsv »
Description
This issue occurs whenever your Mod.io token becomes invalid. You can resolve this issue by renewing your token.
1) Navigate to: %localappdata%\Insurgency\Saved\Config\WindowsClient
2) Open the "Engine.ini" file.
3) Delete the bottom portion under [/Script/ModKit.ModIOClient] and save the file.
The next time you click on the Mods option in the in-game menu, you will have to re-accept the Mod.io terms of service. After that, a new token will be generated for you, which should fix the issue.
Tellus
7
Re: Server Mods
Post by Tellus »
If you're lazy like me, connecting through IP address bypasses the whole issue for some reason.
Ours is pinned in the sandstorm discord channel (87.98.157.13:7777).
Hairy Frog
7
Re: Server Mods
Thx for the tips.
Rat, even a search in the whole PC didn't give a result. any hint about where I should find this directory ?
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
Tellus
7
Re: Server Mods
Post by Tellus »
You can open local app data in the run window (Windows + R key to open) and typing in %localappdata%,
or search for %localappdata% in the menu search bar,
or open Rat's folder directly though the path:
C:\Users\USERNAME\AppData\Local\Insurgency\Saved\Config\WindowsClient
(Just swich the "USERNAME" with your own username.)
The folder itself is hidden I believe, so you won't find it unless you use a direct path to open it or change the settings.
Hairy Frog
7
Re: Server Mods
OK, file fixed, let's check ...
.... it worked ! :mrgreen:
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
