In-game voice problem solution
Me and Caie (Caie and I?) both had an issue where our in-game voice chat wasn't working. For you everything looks ok - you can press your push-to-talk key and the "transmit" icon appears. But other players can't hear you, and the icon does not appear for them. It happens when in close proximity and using the radio channel. WTF?
It appears the game was not using the correct input device. You can't change the device from inside the game, but in Windows 10 you can actually change which sound devices each application uses in the "Sound settings". To fix it for us, we did the following:
  • Start the game
  • Alt+tab back to desktop, go to "Sound settings" (can just type "sound" in the start menu)
  • At the bottom under "Advanced sound options", click "App volume and device preferences"
  • Find Insurgency in the list of running programs, open the Input (bottom) dropdown - it will probably just say "Default"
  • Pick the microphone you want to use explicitly
And that's it! Other people should be able to hear you in-game again. Shouldn't even need to restart the game, and the setting will be remembered in the future. Until it isn't. I actually had to make this change ages ago to force the game to use my standalone mic, but somewhere between game updates and Windows updates the setting got reset. Worth checking if your in-game voice stops working again.
Admiral of the Fleet
Re: In-game voice problem solution
Post by Spawnsy »
Good shout.
Small update on this - I didn't notice when it happened, but it seems in more recent updates to Sandstorm they've finally added the ability to change the microphone used for voice chat directly in-game. You can pick it from a dropdown in the Voice Chat section of the Audio options. Should hopefully mitigate having to faff about in Windows if you have issues with in-game voip in the future :)
Hairy Frog
Post by Hairy Frog »
sounds like windows update blues ... although in the case of Logitech gear, the driver auto-update is also liable to produce this kind of unpleasant trick
If a guy who lost his touch with the real world is a fool, what to think about people who are confusing
- Hanger and hatred
- Respect and fright
- Offense and fear
- Truth and belief
- Knowledge and information
- Love and concupiscence
- Being and having
