Custom Theatre
- Vice Admiral
- 6
- Contact:
Re: Custom Theatre
Last Update of 2024 (probably)
Hey guys, hope you're all enjoying the holiday season! Since the game updated to 1.17 we've had a few more changes so I wanted to summarize them here
New Weapons from 1.17
1.17 brought us 3 (and a half) new guns. Our mod has some additional changes to them:
A few other minor weapon changes have been added:
A bug was pointed out to me with sight alignment for scopes on some weapons. Essentially the viewmodels for a few guns appear rotated slightly upwards when aiming to line up the iron-sights on the model, but this rotation isn't "undone" when using a scope, meaning they can sometimes be misalinged slightly. It was most noticeable on the back-up iron-sights on some scopes. I've added some code to an existing mod on the server to correct for this, let me know if you see any issues with sight alignment on any guns.
There is also a new bug affecting users of Picture-in-Picture scopes where the sight picture appears very small on specific optics (G36 unique 1.5x and 3x scopes, AUG 1.5x A1 scope, PSO-1 4x on AKs). I've also tried to account for that. Let me know if you're using this setting and have any issues with scopes looking wrong or having a big "border" around the scope image.
Bot Changes
The AIModifier mod we're using has been getting regular updates, along with that I've been tweaking the bot parameters to try and refine them (with some help from @Clyarion!) to behave more fairly. Still working on getting them "just right" and reducing the amount of random insta-deaths while still keeping them challenging to fight. I've made some changes to their accuracy which should hopefully make it fairer - the bots should start shooting a bit sooner before they are fully aimed at you, which should help signal you're being targeted. This is meant to avoid the case where a bot has seen you before you see them, and takes a few seconds to line up a perfect headshot out of nowhere rather than start shooting/suppressing right away.
In the latest update it seems that the old behaviour where bots would be "triggered" by players entering the objective has returned. This means that as you kill bots, most of the reinforcements will just hang around at the next point until you jump on the objective which will prompt them to come rushing in. I'm not sure how possible it is to make them always push the point instead, but in the meantime be mindful when entering the point, even to clear out one last bot, grab a rocket launcher off the ground or place down ammo drops. Make sure the team is ready because it will draw in more enemies.
As always any feedback or suggestions are welcome. Thanks all for coming back to play week after week, these changes mean nothing without you guys being here to enjoy them! Looking forward to many more shenanigans for 2025 and beyond
- WCX (it's a Sig MCX Spear LT but renamed to be legally distinct, or something)
- Added drum mag upgrade
- Extended mag now costs 1 point to align with other guns (was 2)
- Enhanced magazine compatibility - you can scavenge AR-pattern mags for it now
- Added Explosive Launcher underbarrel upgrade for the Grenadier class, by default it only had smoke available
- Supports Wrapped Suppressor
- Added Silver and Dark weapon skins
- AR7090
- Made it so the integrated iron-sights can be used alongside the carry-handle sights
- Added 1X Flip-Up Sights upgrade which removes the carry handle, giving a clearer sight picture for the iron-sights
- Supports Wrapped Suppressor and Rugged Suppressor
- Added Alternative Sounds upgrade. This borrows the weapon firing sounds from the L85A2, for those who find the unique sound it uses by default somewhat jarring
- F2000/Tactical
- Enhanced magazine compatibility - you can scavenge AR-pattern mags for it now (including drums!)
- Not many other changes possible yet, as these weapons are broken in the modding tool currently
- Added Full Auto Conversion upgrade for the M16A2 and M16A4. It replaces the burst firemode with full-auto. Costs 5 points!
- Added Advanced Suppressor for the WCX and MK18. This suppressor has a more "integrated" appearance. As well as suppressing the weapon, it also reduces recoil significantly at the expense of lower muzzle velocity/damage. Costs 5 points
- Added the C79 4x-1x scope to a few weapons it was missing from (AKM, AK-74, RPK, PKM)
- Small improvement for the RPK - enhanced the magazine compatibility, so you should be able to scavenge all kinds of AK mags for it now (including SKS mags)
- Added Gold weapon skin for the Desert Eagle
Bot Changes
- Admiral of the Fleet
- 6
- Contact:
Re: Custom Theatre
Awesome. Can't wait to get back online. I'm still working on the new cupboard setup.
- knightmorphed
- Warrant Officer
- 6
- Contact:
Re: Custom Theatre
Good luck with that setup
Hope it will be operational soon
- 6
- Contact:
Re: Custom Theatre
It was great fun last night. No single person ruled the scoreboard (Nova seemed diatracted
). We didn't give up on, or lose a map. Lots of chat and laughs. Plenty on. The server chucked a bot or two into the sky. There was the odd minor complaint but it was very playable and kept us communicating.
Well done Peg.
Well done Peg.
- Vice Admiral
- 6
- Contact:
Re: Custom Theatre
Thanks! Glad to hear it went well Spawnsy
Sorry I missed that session but I should definitely make the next one.
The AIModifier mod got a new update which looks like it may help with the bots pathing to objectives! Looking forward to trying it out.
I also pushed a new update for the theatre which enables shadows for flashlights properly, meaning they won't shine through walls for other players anymore and should look correct in spectator mode etc. May potentially come with a performance hit so do let me know if there's any issues with it, can try to make it an "opt-in" feature if so.
- Vice Admiral
- 6
- Contact:
Re: Custom Theatre
Hey guys, haven't made one of these in a while so figured I'd post an update on what's new with the server/mods:
Bots
For a while now we've switched back from AIModifier to running the original ImprovedAI mod again with a few tweaks to the config. Turns out the main reason ImprovedAI was getting boring before was due to a bug preventing our bot settings being applied correctly. This has now been worked around!
AIModifier has been getting updates, one of which is meant to address the issue of bots not attacking objectives (no word on shooting through smoke sadly) so I am going to test that again at some point soon and see how it stacks up.
Mods
An update to the Custom Sights mod now allows you to also customise your laser sight. The intention is to add more features (like a tri-laser) later, but for now you can just choose the colour. It should work for all players in the match like the optic customisation does. If you encounter any issues with it please let me know!
Theatre
A few new minor additions have been made to the theatre mod, mostly new weapon upgrades:
Last week we tried a few rounds of Skirmish and it didn't actually suck! Off the back of that I've updated the theatre to include squad and class layouts for PvP gamemodes, meaning our new class setups and gear are (mostly) available. I've made a few minor changes compared to Coop to keep it balanced, if we try playing it again let me know what you think:
As always any feedback or suggestions welcome, thanks again for continuing to come back and keep the server busy every Friday!
Bots
Mods
Theatre
- Mini Red Dot and Mini Green Dot 1x optics added to a large number of primary weapons. It basically lets you use the small reflex sights usually reserved for the pistols, but now on your primary. You can use it on most guns although it's excluded from any where the model wouldn't fit or the sights get obstructed.
- PSO-1 4x scope has been added to the SKS. You can swap to the iron sights for close range too.
- A new version of the AUG 3x scope has been added, including a Mini Green Dot backup sight mounted to that conspicuously unused rail on top.
- Some scopes have been changed to let you switch to the weapon's iron sights where available. This affects:
- PK-AS 1.5x scope - AKM, AK-74, AKS-74u, RPK, SVD
- 3x Scope and M150 4x scope - M16A2
- Added the Wrapped Suppressor upgrade to the F2000 and F2000 Tactical
- "Laser Light Combo" siderail upgrade added. As the name suggests it lets you get the best of both worlds by equipping both a laser sight and a weapon light at the same time! Cycle through laser/light/off with your usual siderail keybind. Currently you can't switch on both the laser and light at the same time, but will try to make that work in the future. It currently supports most guns where the models would fit.
- New "Low Profile" and "Tactical" laser sight upgrades added. These basically just let you use an alternative laser sight model on some guns where they fit.
- New alternate flashlight upgrade added for some Insurgent pistols with a more "tactical" look.
- A script has been added to try and correct the sizing of the upgrade dropdown menus which prevents them from extending off the screen or behind other UI elements. This affects the Training and Siderail slots. Those dropdowns should now get converted into scrollable boxes before they become obstructed, especially useful now some weapons have quite a few upgrades in those slots.
- By default we get 20 supply points in Versus, as opposed to 60 in Coop
- The Sniper class is not available in Versus
- Weapons are faction-specific, following the same assignment as the base game
- M93R goes to Security, PF940 Auto to the Insurgents
- Weapon upgrades including all optics are now shared across both factions
- Drum Magazines and some Extended Magazines are not available in non-TDM modes
- Extended Mags blocked for the FAMAS, AUG, MDR, G3, FAL, ACE-52, Tavor-7, MK17, PF940 Auto
- All classes can now use Suppressors, but they cost more for classes which don't normally have them in the base game (6pts)
Re: Custom Theatre
I really enjoyed the vs mode. It was just a nice quick match but was fun. Gives a little break from beating up bots to beating up each other
Hellooo
- 6
- Contact:
Re: Custom Theatre
Herculean efforts peg. All hail Server Daddy.
Ive never been a fan of pvp, but shall endure it's natural rotation as spacechimp endures ministry.
- Vice Admiral
- 6
- Contact:
Re: Custom Theatre
Hey guys, been about 2 months so I figured it was time for another update on what's going on with the server
1.18 Released
We finally got a new full game update! Version 1.18 comes with a new map Forest and 2 new LMGs for the Gunner class - The M250 and H21.
Forest has been added to the map rotation for Checkpoint Security/Insurgents and Survival. I've also updated the theatre mod to include the new weapons. Let me know if you have any issues with them!
In addition to the usual cosmetics and weapon skins, this time round they've added an integration with Twitch.tv to give you in-game "drops" for watching streamers. The account setup is a bit convoluted but if people want I can make a guide on how to do it. You'll need to watch about 4 hours of participating livestreams to unlock all the items - 1 scoreboard badge and 4 weapon skins.
1.18 "Features"
As always with this game, the new version came with a few surprises.
For now I have removed the Frenzy maps, as I realised they were basically never being chosen anymore. They can always come back again, maybe in time for Halloween! In the meantime the map vote should give a few more regular options to choose from.
Mod Stuff
In addition to the guns from 1.18, we've had a few new custom guns added over the last few weeks, mostly pulled together from half-finished weapons in the game files:
I've also tried to resurrect a new 1x optic from the files - the Red Dot M2. It will look familiar to players from Ins2014, as it's the model used for the Red Dot sight in that game. I'm trying to get the 2x version working, but for now the 1x is available for all primary weapons.
Alongside that it's mostly a few bug fixes so pedantic they are not really worth mentioning. But as always if you have any feedback or suggestions please leave them below, or on Discord, or tell me in person at The Meet!
1.18 Released
1.18 "Features"
- Cosmetics - you may notice your cosmetics getting scrambled on starting up the game. There isn't a confirmed fix for this yet, but I believe it will only affect the last preset you selected. So a workaround is to make a new character preset at the menu to use as a throwaway, and make sure you select it before closing the game. It's a pain I know, but hopefully it gets fixed by the devs soon.
- Uniform Camo - several clothing items, mostly in the Torso category, don't work properly with the Uniform Camo option anymore. They will use a flat colour instead. Take the opportunity to make some new combos, such as black Soft Shell jackets! No idea if this will be reverted or if they will add new variants to let us keep using them.
- Scopes - some players have reported issues with 2x scopes not working at all/just appearing black. Not sure what's causing this exactly, if it happens to you, I guess it's time to learn how to hip-fire...
- SVD - I doubt this will affect many of us, but if you like to use the SVD with either the Aiming Grip or Quickdraw Grip, a bug with the animations will make using any optic appear too zoomed-in/broken. The workaround is to avoid those underbarrel upgrades, and if you get one from
Survival crate, ditto on the hip-firing!
Mod Stuff
- UMP45 (Breacher) - A .45ACP SMG with a slow controllable fire rate.
- MP40 (Breacher) - WW2-era SMG for the nostalgic feel.
- Galil ARM (Rifleman et al) - a 7.62x51mm version of the Galil assault rifle. Packs enough punch to rival the MDR!
- Saiga 12 (Breacher) - everyone's favourite semi-auto shotgun. Yes, you can have drum mags with it, but with the drawback of reduced ammo carrying capacity, a lot of instability while shooting, and a big supply cost!
