Insight, tips, tricks. No chat plz.
- 0verzeal0us
- Vice Admiral
- 6
- Contact:
Re: Insight, tips, tricks. No chat plz.
Thankfully, 1.7 hotfix 5 is meant to fix this
Fall forward. Sometimes, it’s the best way to figure out where you’re going. Never be discouraged, never hold back, give everything you got, and when you fall throughout life remember this: fall forward. Denzil Washington
We’re not the avatars we create. We’re not the pictures on the film stock. We are the light that shines through. All else is just smoke and mirrors. Distracting, but not truly compelling. Jim Carrey
I am neurodiverse and communication can be difficult for me. If you would like to know more about neurodiversity, please click here.
- Admiral of the Fleet
- 6
- Contact:
Zel mate: please don't quote the post immediately above your own. If you're referring back to a post made a while ago, fair enough. Thanks.
- Vice Admiral
- 6
- Contact:
Regarding the annoying lag/stuttering that started after the latest update: @Spawnsy and I have figured out a temporary fix. When the stuttering starts, Edit: No settings change needed, just go to the Video options and click Apply! The stuttering should be gone for a few minutes at least. You're free to change the setting back again afterwards if you want. I find I need to do it maybe 2-3 times in a full round, every 10-12 minutes or so.
Some nerdy speculation: I suspect the cause of the stutter is a leak - perhaps memory, or maybe threads getting stuck/not terminating. Basically the game is taking resources (memory/worker threads) from your PC (mainly GPU?) but not releasing them when it's finished using them. So instead of re-using them later it will just take more. After a while your PC runs out of resources to give, or at least runs low enough on them that it has a noticeable performance impact, which makes the game stutter! That might also explain why @Spriggs's PC fans started going crazy while he was playing - everything is going into overdrive to keep up with the increasing demand on your system. When you update your Video settings I guess it forces the game to release whatever stuck resources it was using, and start the cycle from the beginning again.
If that is the case, you could even try doing the fix preemptively whenever you die, it might stop you from experiencing the stutter entirely!
Last edited by peglegswansoon on Fri Sep 11, 2020 9:21 pm, edited 1 time in total.
Some solid pondering matey, thanks for the infopeglegswansoon wrote: Wed Sep 09, 2020 9:04 pm Some nerdy speculation: I suspect the cause of the stutter is a leak - perhaps memory, or maybe threads getting stuck/not terminating. Basically the game is taking resources (memory/worker threads) from your PC (mainly GPU?) but not releasing them when it's finished using them. So instead of re-using them later it will just take more. After a while your PC runs out of resources to give, or at least runs low enough on them that it has a noticeable performance impact, which makes the game stutter! That might also explain why Spriggs's PC fans started going crazy while he was playing - everything is going into overdrive to keep up with the increasing demand on your system. When you update your Video settings I guess it forces the game to release whatever stuck resources it was using, and start the cycle from the beginning again.
I survived the great server crash (23/10/2018)
Gone but never forgotten
- Vice Admiral
- 6
- Contact:
In the dev livestream today, they announced another potential fix for the stuttering.
In Steam, set the launch option "-NoGlobalInvalidation". That's it. If you're already using another launch option like "-dx12" you can use both, just separate them with a space
Thanks to Bob on Discord for pointing out that the devs posted the wrong option, I've updated this post.
one thing you could try is C:\Users\USERNAME\AppData\Local\Insurgency\Saved\Config\WindowsClient should have a GameUserSettings.ini delete that one file and try again. This was a known fix for graphics problems, (it re-sets in-game graphics), it was recommended after ever update about 2 years ago, I still do it after every update, no problems since.
Found out why I couldn't join the server the other day, more nwi bs, something about a token being out of date. Anyway found this fix https://trello.com/c/xbJfnRTp, now I can get back on the server.
