Computer Troubles.... (likely Graphics related)
Re: Computer Troubles.... (likely Graphics related)
Post by BillBailey » Tue Oct 24, 2017 9:44 am
Check the chart on the following link for PSU requirements
http://www.realhardtechx.com/index_archivos/Page362.htm
Post by Ztranier » Tue Oct 24, 2017 10:16 am
again a nice research post BillBailey!!!
Twitter: https://www.twitter.com/0v3rz34l0u5
Facebook: https://www.facebook.com/0v3rz34l0u5/
Post by 0v3rz34l0u5 » Tue Oct 24, 2017 8:10 pm
350w is the minimum for that card but of course, I’d recommend 650 plus!
Profile Picture Credit
Post by Ztranier » Wed Oct 25, 2017 1:24 am
i think you didn´t read the link Bill sended earlier Zealous,
the 950 itselfs already requires 380W, so a 350W PSU won´t work!!
Post by Chris_86 » Wed Oct 25, 2017 12:45 pm
You need to optimise efficiency for your average max load since that's when your power bill will be hit the hardest.
Ideally, under typical gaming load, the PSU should be at around 50% load, where it is typically most efficient. At lower usage levels (i.e. system is idle), the PSU is less efficient but the lower power draw at idle negates that inefficiency.
Bill's link shows you your GPU's min requirements; you also need to account for drives, LEDs, CPU, motherboard, peripherals, fans, etc etc.I would say you need at least a 700 watt PSU, but I would go for an 850 watt to give you greater efficiency at peak loads (not to mention the PSU fans will be quieter.
At the moment I have a GTX 1080, 7700k CPU overclocked, three drives, LEDs, LED fans, and my PSU fan comes on when gaming or benchmarking - this is before USB peripherals such as webcam, mic, keyboard, mouse, document scanner and Raspberry Pi. I really ought to have an 850+ watt PSU, but at the moment it's 750 watts which doesn't leave me with a massive amount of headroom.
Corsair PSUs are very good and efficient. SeaSonic and SuperFlower are also very, very good. Don't skimp on your power supply - perhaps jump on those Black Friday sales if you can wait that long! In the meantime, you can turn down your graphics settings to tide you over.
Post by BillBailey » Wed Oct 25, 2017 1:07 pm
@-kro, is the problem solved now.
TokaiTele
Lieutenant
Lieutenant
Steam: http://steamcommunity.com/profiles/76561198028417860/
Post by TokaiTele » Wed Oct 25, 2017 4:16 pm
What was the solution? You can't just say it is solved and leave us hanging!! Billy boy :-)
Post by BillBailey » Wed Oct 25, 2017 4:21 pm
I didn't say it was solved, I asked if "THE PROBLEM HAD BEEN SOLVED" pay attention Tokai.
TokaiTele
Lieutenant
Lieutenant
Post by TokaiTele » Wed Oct 25, 2017 6:30 pm
Attention? Must try harder. Sorry mate, bit distracted at the moment.
Post by 0v3rz34l0u5 » Wed Oct 25, 2017 7:57 pm
I was basing my figures on this :)
https://www.geforce.com/hardware/deskto ... ifications
