[GUIDE] Insurgency: Sandstorm configs for low-ends
Post by Kentone » Fri Aug 31, 2018 10:29 pm
And by low end, I say at least:
8GB RAM
2GB GPU (Tested on 750ti Boost)
i3 7100
NEW INSTRUCTIONS!
If you have 16 GB of ram this should make not a lot of change in performance, this is for the people that plays with 8GB!
Put all the graphic settings to low, maybe you can have the FXAA or the effects a bit up as they shouldn't affect memory a lot
then just go to:
%localappdata%\Insurgency\Saved\Config\WindowsClient\
and edit
GameUserSettings.ini
search for the line starting by:
OverrideOptions=
and on that line, almost at the end change this values:
("r.Streaming.PoolSize", (Value=400,bModified=True)),("r.Shadow.MaxResolution", (Value=512)),("r.Shadow.MaxCSMResolution", (Value=512)
to
("r.Streaming.PoolSize", (Value=100,bModified=True)),("r.Shadow.MaxResolution", (Value=256)),("r.Shadow.MaxCSMResolution", (Value=256)
OLD INSTRUCTIONS - OUTDATED
Well, if you have something near that, if you put the game on low, the game starts to eat RAM until it touches the ceiling, so I found instructions on Reddit:
https://www.reddit.com/r/insurgency/com ... eriencing/
Do the 7th step ^
I tweaked the configs a bit, with the configs from the reddit my memory stays at 7.5GB ram, with the little tweaks I did stays on 6GB
Unzip this files (download button up to the right)
https://drive.google.com/file/d/1NW0L6w ... v9A86/view
Then go to
and backup this files:
Engine.ini
Then, put the files from the zip on that folder and start the game. You should see improvement, at least I played two entire matches, only with some stuttering at certain moments.
Higher power hardware should be benefitted from this as well, it will look like shit, but should go smoother :D
HF!
Re: Insurgency: Sandstorm configs for low-ends
Post by Ztranier » Fri Aug 31, 2018 10:41 pm
thx for your effort Kentone !!!
The Doctor
Able Seaman
Able Seaman
Steam: https://steamcommunity.com/profiles/76561198015880779
Re: [GUIDE] Insurgency: Sandstorm configs for low-ends
Post by The Doctor » Sat Sep 01, 2018 2:31 pm
Due to first impression after installation, your efforts certainly going to help me. Thanks for sharing!
Post by Kentone » Sat Sep 01, 2018 5:16 pm
:D that's the idea!
Lets hope NWI gets the point, and realize not everyone can afford a NASA computer.
The game runs well on the gpu, is just a memory issue :)
The Doctor
Able Seaman
Able Seaman
Post by The Doctor » Sun Sep 02, 2018 7:33 am
But... but.., I bought a NASA computer..!! Well it was on the day Neil Armstrong retired...
My MSI G-series is almost 4 years old and this is the first game where I'm being confronted with the ancient Roman adagium: "don'be a cheap ass, update your hardware!".
UPDATE. 8 gb of extra memory did the job, it's playable now. I hope the extra SSD I'll recieve in a few days will make it more comfy.
UPDATE 2: adding a 500gb SSD exclusivly for my Steamfolder results in a shift from 'playable' to "f'*****g awesome beyond comortable" I can now help to secure point A every game instead of entering the game minutes later than te rest... :dancebanana:
Post by warlock359205 » Thu Sep 06, 2018 7:24 am
Didn't know sandstorm was on general release yet if so where?
Post by Ztranier » Thu Sep 06, 2018 8:58 am
no @Warlock, it is not on general release, that will be comming on the 18th September, at the moment there is the Beta 2 going, on which will last till the 17th of September
Post by warlock359205 » Thu Sep 06, 2018 2:53 pm
right I bought it installed but its starting up in a small "slot" window and none of my keyboard controls seem to work so I cant set the game up in the first place eg video ,controls etc , ideas?
Post by Ztranier » Thu Sep 06, 2018 3:07 pm
ahoy warlock
maybe it is the best to have a talk at discord to sort out your problems with sandstorm Sir
gimme a shout when ready for it
Post by warlock359205 » Thu Sep 06, 2018 3:41 pm
oh well another £20 down the pan, when I get time ztrainer I will pop on discord and discuss shitstorm but nothing I have tried makes any difference at all , and if I cant even use the keyboard and mouse , or an xbox controller , then theres not much hope , it will probably go the same way as squad did , refund please!!!!!
