[GUIDE] Configuration for newbies
Post by Kentone » Tue Mar 13, 2018 3:24 pm
I want to post here some of the basics on configuration to play insurgency on our server, as well to link other guides that can be useful for newbs, Jubiliant gave me the idea when he asked me about how to see the compass:
ENABLE CONSOLE:
SET THE COMPASS TO ALWAYS SHOWN:
So you don't have to press the compass key anymore:
On the console, type:
cl_hud_compass_show_always "1"
As newb, you should get used to the cardinal points signaling, instead of say: to the right! on the back!, because it depends on your teammates position.
SET A KEY TO QUICKSWITCH BETWEEN PRIMARY - SECONDARY WEAPON:
This will make you ninjapistol the bots easily:
"R" AS RELOAD AND RESSUPLY KEY:
This will reload when you are off the supply zone and resupply when you are on the supply zone:
bind "r" "+reload; inventory_resupply"
HOW TO TRHOW GRENADES ACCURATELY:
On my other post:
http://www.enemyboat.co.uk/viewtopic.php?f=49&t=3531
LINKS TO PREDOWNLOAD THE MAPS AND THEATER:
On my other post:
http://www.enemyboat.co.uk/viewtopic.php?f=49&t=3680
As always, if you think I should add something, tell me.
Re: [GUIDE] Configuration for newbies
Post by Ztranier » Tue Mar 13, 2018 4:12 pm
good work Kentone :bigt:
Ps.: Translation into english would make it even greater
Post by Kentone » Tue Mar 13, 2018 4:43 pm
Honestly, IDK how to translate my insurgency, the language is automatic D:
EDIT: And I don't know why, maybe they are from Miami, but my game is in spanglish
Mauser
Steam: http://steamcommunity.com/id/gmauser/
Post by Mauser » Tue Mar 13, 2018 5:53 pm
That's very helpful Kentone :angel2:. I've always been bothered by the compass being reset everytime I join so many thanks. Also I will try with the resupply key bind because at the moment I resupply by adding/removing attachments and then click resupply which takes unnecessary time.
EDIT: When it comes to your Insurgency being in spanish I have a guess. I think if you got your language settings in Steam set to be in spanish and you play a game that is Steam friendly, it will use those language settings if available. For example I got my steam in swedish and when I played cs:go (~2-3 years ago) everything was in swedish and that is rarely supported in games today. So the reason it was supported in that game was because it went by the Steam settings, and available because cs is made by Valve (Steam). Insurgency however probably only supports the bigger languages such as Spanish.
JubiliantSG
Steam: http://steamcommunity.com/profiles/76561198423600513/
Twitter: /
Facebook: /
Post by JubiliantSG » Tue Mar 13, 2018 6:33 pm
Allas!
You're the man Kentone! This is very useful! Especially for a newbie like me
Thanks a lot for making this guide I'll definitely use it! :lolz:
Post by Spawnsy » Tue Mar 13, 2018 6:37 pm
to resupply, stand within the blue zone, press f then r
that's it. no need for keybinds.
Post by Kentone » Tue Mar 13, 2018 6:42 pm
Yeah, mine is just an extra ease, also it does not open the supply menu so you can move while you do it :P
Post by Kentone » Tue Mar 13, 2018 6:44 pm
OK, thats very helpful, now my game is in english :D
Users browsing this forum: No registered users and 6 guests
