inflationary respawning
Re: inflationary respawning
Post by Kentone » Mon Feb 12, 2018 5:02 pm
TokaiTele wrote:
Mon Feb 12, 2018 2:29 pm
I have noticed a lot more pubbies asking to be spawned in as soon as they join, so I suspect they have been pandered to by one or more of the newer admins.
I have to say that I did that, sorry, admins spawned me on the past when join (once on EBS), so I though it was good. I started to deny that once Ztranier explained me his opinion on this issue.
What I think now:
-Respawn on technical problems.
-Respawn on late join after map change.
On my opinion should be used as a tool to solve problems not for fun.
The best is play as the server is intended to be played :)
In other cases we can wait, as cap the point often takes 2 or 3 minutes, no more.
TokaiTele
Lieutenant
Lieutenant
Steam: http://steamcommunity.com/profiles/76561198028417860/
Post by TokaiTele » Mon Feb 12, 2018 6:17 pm
Has the respawn ability been removed? I don't have access to that command. Just to let you know.
Cercoza
Steam: http://steamcommunity.com/profiles/76561198064451980
Post by Cercoza » Mon Feb 12, 2018 6:54 pm
What I think now:
Pretty much the same for me.
Post by taran » Mon Feb 12, 2018 6:54 pm
toks, we have removed respawn whilst it is been looked at. console access to other commands should have been restored.
Post by taran » Tue Feb 13, 2018 8:43 am
Had hoped more people would chip in here, so will post and copy it on the discord WO chat.
I feel that we do not need respawn at all to admin the servers well, kick, slay, and ban are essential/. But respawn is a perk in all instances, and sadly has been abused of late, not through malice but people using it following their own rules, so to them its fine. We are just not using the same rules.
it is far easier to remove it completely than to set up a set of rules that need to be adhered to, especially as in all cases rules will always have exceptions, and do we really want to add a strict rule set?
no other game we play gives the admin respawn perks, and yet we manage fine with them?
Post by DarkDeamon » Tue Feb 13, 2018 9:53 am
+1 to what taran said.
You don't need to be spawned in to deal with people.
status - will give you player names and steam id's
sm_hsay "whatever you need to say" - will get a message in the middle of the screen
sm_psay "player name or steam id" "message" - will send a private message to a player
sm_slay "player name or steam id" - will pop their little clogs
sm_kick "player name or steam id" - will get rid of the buggers
sm_ban "0" "player name or steam id" - 0 is a permi ban or you can set it to a time in mins
Re:
Post by Kentone » Sun Feb 25, 2018 1:21 am
Spawnsy wrote:
Sat Feb 10, 2018 11:55 pm
open the console using your ` tilde key.
type exactly, including speech marks:
bind "u" "sm_hsay DO NOT RUSH" enter
bind "I" "sm_hsay ENABLE COMMS: YOU MUST HEAR THE TEAM" enter
bind "o" "sm_hsay EBS ££ = EBS RULES" enter
i think i used to use 890-= as my keys. maybe 7 too, i don't recall. it doesn't matter which, as long as you remember.
i don't recall exactly what messages i used to have either. i think the first two are correct.
some basic things i do remember:
long messages don't work.
keep it short and to the point.
blunt, but not rude.
caps work best: tried and tested.
one i do recall, but which i only used occasionally was: NO ENGLISH: NO GAME
i only ever used it when a player simply wouldn't respond to anything as a last ditch effort before kicking them. it may seem harsh, but if you can't communicate with the team, then how can you play with them? sure, if a person doesn't understand english but joins in perfectly well, then it's not a rule, but if they're a problem, then it's a problem.
mess about and see what gets you the best results. take note of the responses you get from your messages and tweak them.
Reading these im sharing my own spice, if you like:
viewtopic.php?f=49&t=3695#p43770
Users browsing this forum: No registered users and 4 guests
