[HOW TO] Discord fixes and botches
Sub Lieutenant
Sub Lieutenant
Post by Kentone » Mon Nov 20, 2017 7:06 pm
I started this thread for only one problem I had, but appears that discord shows some more issues, so I decided to start documenting here what's broken and how to fix it :D
For now we have:
  • BUGS
  • FIX FOR "OVERLAY NOT SHOWING" - Insurgency only - NOT NEEDED ANYMORE, but if it doesn't work for you, use it
  • FIX FOR THE "MEMBER NAMES NOT SHOWING" - Insurgency only
  • FIX FOR "DIGITAL NOISE" - General Fix
If you find a new issue that is not here, put it on a comment so we can investigate it (^_^)
BUGS
--The server browser does not show up and the loading screen looks glitched while overlay is on - Set a bind to disable the overlay while you use the server browser, enable it again when you are already on the game. Instructions on "FIX FOR THE "MEMBER NAMES NOT SHOWING"".
I asked some people if they can see the discord overlay, and seems like some can't.
So the problem is BattleEye blocking the load of the discord overlay plugin into Insurgency.
This is the way you have to launch Insurgency to play with Discord support:
Go to steam and press the right button of the mouse above insurgency, select "Properties":
Go to the local files tab, and press view local files:
Make a shortcut on the desktop for the executable called Insurgency.exe, NOT Insurgency_BE.exe (BE is BattleEye):
And rename it to something like "Insurgency no BattleEye" or "Insurgency with Discord" (The shortcut pls, not the exe XD)
Launch the game from that new shortcut you created to play on EBS server and use the Discord overlay, remember to configure the overlay first on Discord.
If you want to play on BattleEye protected server, just launch the game from steam, and not from your hand created shortcut :D
I found out another issue that maybe you will face, quite annoying, and its that discord sometimes only shows discord icon on overlay, not the member names, even if you enable "Always show names".
OK! Alt-tab the game, go to discord and press the settings button:
Then go to overlay and disable then enable:
OR
Go to keybinding, and set a key to "Enable/disable overlay", I have the minus key set. This way you don't have to alt-tab to fix the contact list :)
This one was found and fixed by Stubj
Just go to Settings/Voice and video/Quality of service and put the underneath option on "Enable":
And sorry about the spanish screenshots, thats what I have XD
I hope it helps, if you have any issue, feel free to ask me for help :)
Allana
Gender: Female
Re: Discord Overlay fix and Battle Eye
Post by Allana » Mon Nov 20, 2017 7:31 pm
thx a lot fot that post! i will try it and happily see again who is joining.
does the discord overlay with pubg work? it doesnt work with me, so if someone has a hint i am gladly to follow it.
Sub Lieutenant
Sub Lieutenant
Post by Kentone » Mon Nov 20, 2017 9:55 pm
I did not even tryed, but... https://www.reddit.com/r/PUBATTLEGROUND ... _for_pubg/
Maybe that thing helps :/
Allana
Gender: Female
Re: Discord Overlay fixes and Battle Eye
Post by Allana » Sat Nov 25, 2017 1:56 pm
thx for the link. it seems i have to wait for pubg to be white-listed by discord before it can work...
Sub Lieutenant
Sub Lieutenant
Re: [HOW TO] Discord fixes and botches
Post by Kentone » Tue Dec 12, 2017 4:16 pm
Updated - With the new discord update it works with BattleEye
