Just an Idea?
Re: Just an Idea?
Post by Spawnsy » Wed Mar 22, 2017 11:03 am
I think f/f as opposed to auto punish. Is there a friendly fire switch? 1/0?
Gorlami_Raverderche
Petty Officer
Petty Officer
Steam: http://steamcommunity.com/profiles/76561198002898781/
Re: Just an Idea?
Post by Gorlami_Raverderche » Wed Mar 22, 2017 11:47 am
I would suggest lower supply count at round start. Or just use the original 10. Having to choose equipment carefully, and the anticipating of enemy loadouts is a part of the fun. Having an abundance of supply takes away the need to consider those things.
Re: Just an Idea?
Post by taran » Wed Mar 22, 2017 12:38 pm
switch can be changed to warning first then kill.
we can experiment with change each round, so total 3 rounds per map, change each round, win limit is 2 of those rounds?
or total 2 rounds per map, change each map, win limit is 2?
I think 24 was fine going to 32 would be messy.
Re: Just an Idea?
Post by taran » Wed Mar 22, 2017 12:57 pm
done those, also added team autobalance.
not sure about supply as I think set by the theater file? @dark
Re: Just an Idea?
Post by DarkDeamon » Wed Mar 22, 2017 2:15 pm
Supply points set in %gamemode%.cfg file not theater.
I'd reduce them gradually if you're going to change them.
At some point i may redo my theatre to mod the load outs. Will need higher supply points then.
Re: Just an Idea?
Post by taran » Sat May 13, 2017 5:24 pm
Not around for a few sundays for pvp, going awol.
might be able to make the switch if peeps are still up for it, but all will depend on sketchy connections.
Allana
Gender: Female
Re: Just an Idea?
Post by Allana » Sun Jun 25, 2017 9:10 pm
Tonight was pvp again!
Altough there were only between 8 and 12 ppl around it was good fun.
The only problem: after the first pvp map it showed again chackpoints maps - all maps had to be chosen with the console. And the server crashed several times over about 2 hours...
Sunday night should be pvp night!
Re: Just an Idea?
Post by DarkDeamon » Mon Jun 26, 2017 5:07 am
Worked out what was wrong with the maps. Forgot to run a command!
We do keep having a bit of an issue with some of the workshop maps doing updates during map changes on the server though.
Re: Just an Idea?
Post by taran » Mon Jun 26, 2017 8:52 am
Your right, they will update if an update is due, like it would with server stored maps, most though shoudl update at steam startup./
I am a fan of using the workshop as less people are kicked for having the wrong version, mainly newer versions if we use server stored maps, as some of our old maps were ancient,
but it does sometimes go wrong like the map maker updating and breaking the bots like on hastings, fixed now.
Up to you your Darkness.
Allana
Gender: Female
Re: Just an Idea?
Post by Allana » Sun Oct 29, 2017 11:55 am
Since server 1 is down we didn't play any pvp matches on Sunday night.
Are there some other ppl who would like to play pvp again on Sunday evening? Or another evening, Friday for example...
I once changed the maps with the console and it chaned to a pvp map (after the change). So the pvp option is probably still working.
Users browsing this forum: No registered users and 7 guests
