Updates
Re: Updates
Post by taran » Sun Dec 11, 2016 9:56 am
do you want me to do it?
Sent from my iPhone using Tapatalk
Re: Updates
Post by DarkDeamon » Sun Dec 11, 2016 12:20 pm
Crack on and change it. I'll look later on if there is a way to make the suicide bombers avoid spawnsy!
TokaiTele
Lieutenant
Lieutenant
Steam: http://steamcommunity.com/profiles/76561198028417860/
Re: Updates
Post by TokaiTele » Sun Dec 11, 2016 1:06 pm
You're wrong there Hairy Frog. When defending a point you get rushed by the bots. You kill many of them, one of them happens to be a bomber. Yes, he is identified by the fact he is armed with a pistol, but it is very difficult to spot them when defending a zone. Sometimes you have no clue what the bots are armed with because they are hidden behind other bots.
All in all the suicide bombers are implemented badly. The only way that this could be redeemed is if there is an audio cue when the bomber drops the IED, this would give you a chance to run from the blast. Or remove them completely.
Re: Updates
Post by taran » Sun Dec 11, 2016 1:18 pm
removed
Re: Updates
Post by Spawnsy » Sun Dec 11, 2016 1:19 pm
you've played well all round. you've been lucky too. you've saved the team on 3 occasions, taking the time as last man to be careful to make it to, and take the point. you're 80/90/100 for no deaths. you've done everything right, helping out the squad to attack and defend successfully. then on one of the last 2 points you turn to find a bot spawned 2 feet outside the door you're on the other side of, and he's coming at you fast. you congratulate yourself on having the awareness to have seen him at all, let alone the reactions to kill him, and as the bot hits the floor you die.
the bomb goes off within a second. there is no chance to run. indication or not. it's almost instant. kill,,,bang. it doesn't fit with the way we play. it doesn't reward teamwork or careful play. it's just a random death for no reason, and i absolutely fucking hate it.
edit. thank you taran.
Hairy_Frog
Chief Petty Officer
Chief Petty Officer
Steam: http://steamcommunity.com/profiles/76561197971773657/
Location: Between Bordeaux and the ocean, not far from my amp and guitar
Re: Updates
Post by Hairy_Frog » Sun Dec 11, 2016 4:36 pm
... and even if you run, the blast radius will almost always catch you.
Reason why I suggested these bomber bots should only spawn alone, and never mixed in an assault squad given this is possible to fix the .cfg like this
Aristote : to be, is to do
William S : to be,or not to be
JP Sartre : to do is to be
F Sinatra : do be do be do
TokaiTele
Lieutenant
Lieutenant
Re: Updates
Post by TokaiTele » Sun Dec 11, 2016 5:17 pm
Not necessarily frog. I've played on servers where bombers were prevalent. When they were killed you could hear the IED drop, this was your cue to get the fuck out of there. This gives enough time to get out of the blast radius.
However I can see you like to have the last word so feel free to rebut my comment.
Updates
Post by taran » Sun Dec 11, 2016 5:28 pm
On daiymu servers they shout "allah akbar"as they run at you, very very scary.. from that moment on you kinda know you are screwed, only pure headshots take them down.
All of the above spawn suggestions can be done via the cfg but not worth spending the time on it , spawnsy says he f*^&*&8 hates it..
lets say farewell to SB for some time.
In squad they are adding ieds, that can't be seen, that is really going to be messy.
Re: Updates
Post by DarkDeamon » Wed Feb 08, 2017 2:49 pm
The feckers have patched - prepare for broken things....
http://steamcommunity.com/games/insurge ... 6194664544
And they've been fiddling with sourcemod the feckin camel humping, lice infested, cockwombles
Re: Updates
Post by taran » Wed Feb 08, 2017 3:32 pm
I have updated server 1, will do 2 next..
redzones are gone and a few other nice treats are also gone.
