Dice LA Camo
Chat about BF4, obviously...
ReActIonZz
Leading Rate
Leading Rate
Steam: http://steamcommunity.com/profiles/76561198244414772
Dice LA Camo
Post by ReActIonZz » Thu Sep 22, 2016 2:49 pm
Anyone been through the unlock on Dragon Valley to get this?
Kawa47
Petty Officer
Petty Officer
Steam: http://steamcommunity.com/id/Kawa47NL
Re: Dice LA Camo
Post by Kawa47 » Thu Sep 22, 2016 3:34 pm
Yes i got on a server where they help you , it's a lot off work if your alone. Will look later if I still have the server in my favorite list.
ReActIonZz
Leading Rate
Leading Rate
Re: Dice LA Camo
Post by ReActIonZz » Fri Sep 23, 2016 9:45 am
I have an app on my phone that helps with this, works out the light sequence and has a morse code translator.
It looks straight forward enough, just might take 30 minutes of my time setting the switches in the map.
If you have the server info that might also help.
Bit late to the party, but it is something that i want to achieve.
Kawa47
Petty Officer
Petty Officer
Re: Dice LA Camo
Post by Kawa47 » Fri Sep 23, 2016 12:57 pm
Don't have it anymore in my favorites. Doesn't work in empty server and is hard in a full one. Thrust me it's not as easy as it looks.
Facebook: https://www.facebook.com/bill.bailey.9212301
Re: Dice LA Camo
Post by BillBailey » Fri Sep 23, 2016 2:02 pm
Also, your gun still glows through irnv and flir, so it's pretty useless
Users browsing this forum: No registered users and 1 guest
