Dead pc
Non-game related chat
Or4ngeSt33l
Steam: http://steamcommunity.com/id/ Or4ngeSt33l /
Dead pc
Post by Or4ngeSt33l » Sun Oct 01, 2017 7:29 pm
Sorry lads won`t be on for a while pc has die a death :cry:
Re: Dead pc
Post by Stujb » Sun Oct 01, 2017 7:51 pm
noooo bad news mate, what's happened?
Re: Dead pc
Post by Ztranier » Sun Oct 01, 2017 7:53 pm
oh shit, bad News m8
Or4ngeSt33l
Re: Dead pc
Post by Or4ngeSt33l » Sun Oct 01, 2017 7:58 pm
Not that I know shit about pcs ,thought it was monitor but not getting any signal from pc got power sounds like its starting but nothing happening
Re: Dead pc
Post by 0v3rz34l0u5 » Sun Oct 01, 2017 8:38 pm
Could it be the power supply?
Re: Dead pc
Post by Ztranier » Mon Oct 02, 2017 11:10 am
on board Batterie?
Re: Dead pc
Post by BillBailey » Mon Oct 02, 2017 12:55 pm
Does your PC have a built in motherboard monitor output, if so plug your monitor into that and see If you get a signal.
alex4germany
Sub Lieutenant
Sub Lieutenant
Steam: http://steamcommunity.com/profiles/76561197995338803
Facebook: http://www.facebook.com/profile.php?id=100000265784610
Re: Dead pc
Post by alex4germany » Mon Oct 02, 2017 7:53 pm
Remove all your RAM modules and insert them all back properly.... if this won't help remove them all again and only use one of them in the first slot. If it won't help, try doing it with another one. I think most likely one of your RAM modules is not properly in place or broken.
Before doing this whole RAM-thing, you might want to try removing your gfx card first and put it back into the slot properly.
This kind of error you described most likely happens when something is not placed properly in its slot, maybe because of some kind of concussion that happened. GL
Last edited by Chuck Norris on Fri Jun 6, 2142 6:66 am, edited 666 times in total.
Re: Dead pc
Post by warlock359205 » Mon Oct 02, 2017 8:15 pm
start at the beginning, was it fine the last time you used it? any odd stuff going on if so like what? if as you say it "sounds " like its firing up then its not your psu so the next choice is probably graphics, so turn it OFF and take the side of the case off , go and PLAY WITH THE BATHROOM TAPS, to make sure you don't have any static on you, then start by as someone else said ,IF you have onboard graphic try plugging that in first and if you get a signal then its definatly a new graphic card, if theres no signal then try removing your card (carefully ) and push it back in, sometimes you get a slight carbon build up on the pickups and by removing and putting it back can clear that problem, then if this still don't work try the memory sticks option as someone else has also said. or if you have a good mate who would lend you a spare psu to try
Or4ngeSt33l
Re: Dead pc
Post by Or4ngeSt33l » Wed Oct 04, 2017 11:00 am
Thanks for your help lads have tried what you said not working ,looking to get new pc as mine was getting on .Hopefully see you all soon
Users browsing this forum: No registered users and 5 guests
