New Build help
DOOSDIEF
Facebook: https://www.facebook.com/marius.jacobs
New Build help
Post by DOOSDIEF » Sat May 26, 2018 11:33 am
Hi, Guru's.
I am investigating some option of getting an upgrade to my current system. This is what I have in mind. any feedback, suggestions will be welcome. Budget is tight but I need to future proof as much as possible.
I will post Images in comments as I don't know any other way. lol
Than you in advance. Doosdies
DOOSDIEF
Re: New Build help
Post by DOOSDIEF » Sat May 26, 2018 11:36 am
nope can't even get this to work. lolol
DOOSDIEF
Re: New Build help
Post by DOOSDIEF » Sat May 26, 2018 12:01 pm
Giving up. Will try discord. hanks in any case
Re: New Build help
Post by BillBailey » Sat May 26, 2018 2:05 pm
You didn't actually give us any idea of what you had in mind in your first post mate. Why don't you expand on it a bit, such as budget, whether you want an AMD or Intel system etc....
Re: New Build help
Post by Age. » Sat May 26, 2018 5:09 pm
DOOSDIEF
Re: New Build help
Post by DOOSDIEF » Sat May 26, 2018 8:02 pm
cheers Age.
AnimusEradico
Re: New Build help
Post by AnimusEradico » Sun May 27, 2018 2:15 pm
Lot's of research is my advice! And shop around for the best price on each part.
Check out benchmarks and reviews of components you're interested in, check for compatibility etc. I started off with thinking about the CPU and went from there.
Might be worth considering if you want to go down the air cool or liquid cooling route as that can help inform decisions on case size, PSU demand etc.. it's also expensive in my opinion to go the radiator route.
Also consider how much expansion you might want down the road and how compatible that will be.
