Manually spin-down a internal hard drive to have a quiet life
Re: Manually spin-down a internal hard drive to have a quiet life
Post by HonorOfDuty » Sun Jan 21, 2018 7:56 pm
Check this out https://www.transip.nl/stack/# it's free 1tb storage, safe and no strings attached. The website is in Dutch though because it's a Dutch company.
Post by Chris_86 » Sun Jan 28, 2018 6:59 pm
Yeah there's no way I'm trusting my files with a cloud provider. I backup my stuff with Acronis daily but a) that's client-side encrypted and b) I can choose the location of the data-centre and c) I actually pay money for the service, which I find reassuring, because the money has to come from somewhere.
Gunganator
Able Seaman
Able Seaman
Steam: http://steamcommunity.com/id/Gungy
Post by Gunganator » Fri Feb 09, 2018 2:01 pm
Is it a sata Drive, If it is it supports hot plugging. just disconnect the power till you require it.
Direct from WD themselves
SATA-compliant devices thus need no further modification to be hot-pluggable and provide the necessary building blocks for a robust hot-plug solution, which typically includes: Device detection even with power downed receptacles (typical of server applications)
Pre-charging resistors to passively limit inrush current during drive insertion
Hot-plug controllers to actively limit inrush current during drive insertion
*******Warning********
In order to take advantage of hot-plug capabilities for your Serial ATA hard drive, you must use the Serial ATA power connection, not the Legacy (Molex) power connection. The Legacy (Molex) power connection does not support hot-plugging.
hope this helps
Post by 0v3rz34l0u5 » Fri Feb 09, 2018 6:37 pm
Does anyone use molex anymore?!
Post by Kentone » Fri Feb 09, 2018 7:41 pm
Also I think you mobo has to support hotpugging
