Mumble use
Mumble use
Post by taran » Fri Aug 12, 2016 6:44 pm
Hi
Have installed Mumble, tested it and seems to work, have a few noob questions..
Do you set up mumble so that the push to talk key is different to Insurgencies push to talk key? So are you repeating your mumble instructions to the squad in both?
I see the main server, and I see #tough which is says is gbh server one, so if playing on that server connect to that one with a different pw, if on abh server which do you connect to?
thanks
Re: Mumble use
Post by DarkDeamon » Fri Aug 12, 2016 7:07 pm
Please do setup your PTT keys different otherwise you echo
The two insurgency sub-channels relate to server 1 and server 2. The idea is that you join the mumble channel to match the server you are on, no different passwords required. It doesn't always happen like that so sometimes you may get moved around if Spawnsy or Me are on.
The only time you may see a password in the insurgency mumble channels is if we are having a closed members only session or i've locked the server to keep the pubbies out while I do some testing. If you ever open insurgency and see the padlock against one of our servers, then look in the mumble channel comments for the password though it's often something pork products related if I've set it!
Re: Mumble use
Post by taran » Sat Sep 17, 2016 4:49 pm
so banging my head
guys tell me my mumble mic audio is fine but in game is v quiet
changed settings in steam and insurgency to max volume and turned down mumble volume hoping to reach a happy medium but voip still to low
Usb hypex 2 cloud headset so a nice piece of kit
it's a mumble in game conflict I am guessing
you guys all seem to be fine
any ideas
Sent from my iPhone using Tapatalk
Re: Mumble use
Post by Spawnsy » Sun Sep 18, 2016 12:47 pm
ok mate. my mumble config.
input:
default device
multi channel
ptt
off
off
compression
quality 40.0
audio per packet 20ms
processing
noise supression -30db
max amplification 40
output:
wasapi
default
positional audio
jitter buffer 10
voume 100%
output delay 30ms
attenuate... 50%
while other users talk
headphones
1m
150%
15m
80%
loopback none.
i hope this helps mate.
Re: Mumble use
Post by BillBailey » Sun Sep 18, 2016 2:51 pm
Here's some pics to help.
Bear in mind i'm using a USB headset.
Re: Mumble use
Post by taran » Sun Sep 18, 2016 2:56 pm
thx both
I followed the guide here on the forum
found out if you unclick let applications have exclusive rights in Windows recording properties it helps
I also think that mumble is far more intelligent the way it optimises volume than insurgency
so mumble always sounds fine but in game it's less so advanced and hit or miss
if your mic is very close its ok
when mumble isn't on its fine so mumble is taking audio priority
thx again
Re: Mumble use
Post by taran » Sun Sep 18, 2016 2:58 pm
spawnsy I see you have positional audio on what does this do?
Re: Mumble use
Post by BillBailey » Sun Sep 18, 2016 3:03 pm
Turn it off, its useless.
Re: Mumble use
Post by Spawnsy » Sun Sep 18, 2016 7:33 pm
i thought it was what gives you 3d sound. so i that i might discern the direction of movement detected. is that not correct then bill?
either way, if i don't know, but everything works fine, then i'll leave it working.
maybe you're right about the settings having to tally. could be your mic. dunno.
if nothing makes a difference then we'll have another look soon.
keep us informed.
Re: Mumble use
Post by BillBailey » Mon Sep 19, 2016 6:33 am
Spawns Positional Audio is a feature of Mumble that places the people talking to you in a certain position relative to your own depending on their actual position in the game you are playing. This way you can hear the person like his actual avatar in-game would be talking to you.
