Discord malware
Re: Discord malware
Post by Ztranier » Sat Oct 26, 2019 12:30 pm
they got me also
can´t even uninstall Disord
Potential Discord Malware fix
Post by 0v3rz34l0u5 » Sat Oct 26, 2019 8:05 pm
I've written a script that may fix the issue with Discord (I've not been infected so I can't say).
Download both files from https://1drv.ms/u/s!Altmhqse1obagQWFIlR ... J?e=Q8afm0 onto your Desktop. Simply run "Open PowerShell_ISE.bat" (as an administrator) and the press the green arrow to "play".
In short, the batch file opens the PowerShell script and then it deletes the index.js file from %AppData%\discord\ver\modules\discord_modules and then re-creates it with the correct code "module.exports = require('./discord_modules.node');"
For those who are interested, the contents of the files are
for /f "tokens=2*" %%a in ('REG QUERY "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders" /v Desktop' ) do set "desktopPath=%%~b"
set filePath="%desktopPath%\DiscordMalwareFix.ps1"
PowerShell_Ise -file %filePath%
$error.clear()
try {
#Creates temporary PowerShell access to HKCR - deleted at end of script
New-PSDrive -Name HKCR -PSProvider Registry -Root HKEY_CLASSES_ROOT
#Gets the value of (default) in HKCR:\Discord\DefaultIcon\
$discordRegVal = (Get-ItemProperty -path 'HKCR:\Discord\DefaultIcon\').'(default)'
#Gets app-versionnumber from discordRegVal
$regAppVerVal = $discordRegVal.split("\")[6]
#Removes "app- from regAppVerVal
$appVer = $regAppVerVal.replace("app-","")
#Dynamic variable so that index.js can be deleted from the user's AppData
$fileName = "c:\users\" + $env:UserName + "\AppData\Roaming\discord\" + $appVer + "\modules\discord_modules\index.js"
#Deletes index.jx
Remove-Item $fileName
#Dynamic variable so that index.txt can be created
$filePath = "c:\users\" + $env:UserName + "\AppData\Roaming\discord\" + $appVer + "\modules\discord_modules"
$tempFileName = "c:\users\" + $env:UserName + "\AppData\Roaming\discord\" + $appVer + "\modules\discord_modules\index.txt"
#Populates index.txt with safe data"
New-Item -Path $filePath -Name "index.txt" -ItemType "file" -Value "module.exports = require('./discord_modules.node');"
Rename-Item $tempFileName $fileName
#Deletes PowerShell access from HKCR
Remove-PSDrive -Name HKCR
catch {
  $_
if (!$error.length -gt 0) {
$messageBoxTitle = “Success!”
$messageBoxBody = "The file "
$messageBoxBody2 = " has been re-created!"
$newLine = "`r`n"
$question = “Open a browser for further information?”
$messageBoxBodyFull1 = $messageBoxBody + $newLine + $fileName + $messageBoxBody2 + $newLine
$MessageBoxResult = [System.Windows.MessageBox]::Show($messageBoxBodyFull1,$messageBoxTitle,[System.Windows.MessageBoxButton]::OK,[System.Windows.MessageBoxImage]::Question)
    if ($MessageBoxResult -eq "Yes") {
    Start-Process "https://www.bleepingcomputer.com/news/security/discord-turned-into-an-info-stealing-backdoor-by-new-malware/"
else {
$errorMessage = $error[0].Exception.GetType().FullName
$messageBoxBodyFull = ""
$messageBoxTitle = “Error”
$question = “Open a browser for manual instructions?”
$newLine = "`r`n"
$messageBoxBodyFull2 = "Powershell Error:" + $newLine + $errorMessage + $newLine + $question
$MessageBoxResult = [System.Windows.MessageBox]::Show($messageBoxBodyFull2,$messageBoxTitle,[System.Windows.MessageBoxButton]::YesNo,[System.Windows.MessageBoxImage]::Error)
We’re not the avatars we create. We’re not the pictures on the film stock. We are the light that shines through. All else is just smoke and mirrors. Distracting, but not truly compelling.
Re: Discord malware
Post by 0v3rz34l0u5 » Sat Oct 26, 2019 8:06 pm
Not sure if this little script I've written will help @Ztranier. Let me know if it does :)
Re: Potential Discord Malware fix
Post by Ztranier » Sat Oct 26, 2019 8:58 pm
Thx Sel
Re: Discord malware
Post by Ztranier » Sat Oct 26, 2019 8:59 pm
going to give it a try tomorrow Zel
Re: Discord malware
Post by Projectblue » Sat Oct 26, 2019 10:28 pm
Thanks for doing that Zel, I've merged your thread here to keep it tidy.
"The day may dawn when fair play, love for one’s fellow-men, respect for justice and freedom, will enable tormented generations to march forth serene and triumphant from the hideous epoch in which we have to dwell. Meanwhile, never flinch, never weary, never despair."
Re: Discord malware
Post by Ztranier » Sun Oct 27, 2019 9:15 am
No @Zel i can´t open that file in my OneDrive
and it appears that i can´t play naither Sandstorm nor Squad because of the discord plugin
Re: Discord malware
Post by 0v3rz34l0u5 » Sun Oct 27, 2019 10:04 am
Can you download them and put them on your Desktop?
Thank you @Projectblue :)
Re: Discord malware
Post by 0v3rz34l0u5 » Sun Oct 27, 2019 10:09 am
Probably should have shared it 🤦🏻‍♂️. Sorry Z! Correct link is https://1drv.ms/u/s!Altmhqse1obagQWFIlR ... J?e=Q8afm0
I’ve updated the link above also.
Re: Discord malware
Post by Ztranier » Sun Oct 27, 2019 11:38 am
It doesn´t work for me
i cecive a message which say that C:\\Windows\.................\DiscordMalwareFix.ps1 cannot be opend, a part of the path cannot be found
Maybe because i manually tried to dele Discord
