AIO CPU Watercoolers
Post by 0verzeal0us » Sat Feb 23, 2019 9:50 pm
I’ve had a look around the internet but I can’t find anything conclusive.
I’ve had a Corsair H100i for four and a half years and it’s started getting hot. Not ludicrously hot but enough to start heating the room and causing games to lag. Does anyone know if they dry out?
Spadgy
Re: AIO CPU Watercoolers
Post by Spadgy » Sun Feb 24, 2019 2:41 pm
Could be corrosion of the pipework or fouling of the medium making it less efficient. I know in the brewing industry we regularly change out any medium to avoid these issues.
Anything worth shooting is worth shooting twice. Friendly fire isn't friendly.
samuraipxi
Post by samuraipxi » Sun Feb 24, 2019 2:50 pm
I believe the AIO cooler solution is supposed to last the life of the product. My first check would be the dust in the radiator fins, if I was to clean mine I would take it out and blast air through the fins.
Post by BillBailey » Sun Feb 24, 2019 4:23 pm
I'd say the RAD is clogged mate.
Post by 0verzeal0us » Sun Feb 24, 2019 9:27 pm
I thought that might be the case. Unfortunately I think it means stripping it down as the motherboard is in the way. If all goes well, I may be able to attack it from above.
Cheers for the help! I’ll let you know how it goes!
Post by BillBailey » Mon Feb 25, 2019 6:27 am
Get yourself a can of compressed air.
Post by 0verzeal0us » Mon Feb 25, 2019 1:52 pm
I've got a compressor at work which I'm going to borrow!
Post by 0verzeal0us » Mon Feb 25, 2019 6:24 pm
I'm not sure if I also have a broken sensor!
Post by HonorOfDuty » Mon Feb 25, 2019 8:55 pm
It's probably the software. My iCue gives a constant of 147°C for one of the thermal sensors yet I feel see or hear no difference from since i got my pc so I blame it on poor coding.
Post by 0verzeal0us » Mon Feb 25, 2019 9:22 pm
I’ve given it a clean and it definitely seems better. I can feel the fans through the radiator too.
The sensors are reporting a ten degree difference between the CPU and pump. Is that normal or does the paste need renewing?
