Audio cuts off when using Discord & BFV
Post by Projectblue » Sat Dec 15, 2018 9:02 pm
So BFV is amazing and works fine with speakers. However when I use it with headphones/mic and Discord, it cuts off after a while. There doesn't seem to be a regular point where it cuts off, it just goes.
Once it's done that, there is no audio received at all, although I believe people can still hear me when I press the PTT.
Unplugging the headset doesn't restore it.
Turning the speakers on doesn't restore sound.
Only exiting the game and discord and restarting everything brings it back. Only for it to repeat later.
Q: Does it do it with any other games?
A: No. Just BFV
Q: Does BFV work fine without USB Headset - just outputting through speakers?
A: Yes
Q: Does BFV work fine with USB Headset, but not using Discord?
A: Don't know, don't think I've tried that.
Q: Have you looked at Discord Video/Audio and selected default items?
A: Yes. It made no difference
Q: Have you looked at Windows Sound and checked it's detecting/working?
A: Yes, it says it's fine but cannot play test sounds, once it's cut off.
Any ideas? Cos this is really starting to fuck me off. And you all know how calm I normally am.
"The day may dawn when fair play, love for one’s fellow-men, respect for justice and freedom, will enable tormented generations to march forth serene and triumphant from the hideous epoch in which we have to dwell. Meanwhile, never flinch, never weary, never despair."
Re: Audio cuts off when using Discord & BFV
Post by BillBailey » Sat Dec 15, 2018 9:08 pm
Whats the make of your USB headphones Blue.
Hairy Frog
Post by Hairy Frog » Sat Dec 15, 2018 9:17 pm
1) same problem with every usb ports of you pc ?
2 ) headset conected on a sole port or on a usb hub ?
3 ) Have tried a jack plug headset instead of usb ( smartphone headset would do the trick ) ?
If a fool is a guy who lost is touch with the real world, what to think about people who are confusing
- Hanger and hatred
- Respect and fright
- Offense and fear
- Truth and belief
- Knowledge and information
- Love and concupiscence
- Being and having
Post by Projectblue » Sat Dec 15, 2018 10:47 pm
@BillBailey Corsair
@Hairy Frog 1) yes 2) sole port and then via hub to test 3) no. It worked before BFV. It works with other things, eg in game comms in Elite. (Don't know if it works with in game comms in BFV, not tried that).
Post by warlock359205 » Sat Dec 15, 2018 11:03 pm
I use a usb Corsair headset and have no problems but then I don't use discord or haven't yet
Hairy Frog
Post by Hairy Frog » Sat Dec 15, 2018 11:25 pm
Is your speakers system a simple stereo set? or more, like 2+1 or 5-1 or even more complex suround system ... ?
- Hanger and hatred
- Offense and fear
- Truth and belief
- Being and having
Post by Projectblue » Sun Dec 16, 2018 12:31 am
5.1 surround plugged into sound card
Post by BillBailey » Sun Dec 16, 2018 2:37 am
Did you install the corsair software that came with the headset?
Post by 0verzeal0us » Sun Dec 16, 2018 12:25 pm
It's called iCue. Really good bit of software but essential.
Post by Projectblue » Sun Dec 16, 2018 1:44 pm
Yes.
